Tractor Talk Discussion Forum
Super A water pump
Philip Jenkins
02-22-2007 12:18:49
I have a 1953 Farmall Super A. It does not have a water pump. Can I install a water pump on this tractor to help circulation in the cooling system? If so, will I need to make any modifications to any other components?
Thanks.
vally farm
02-22-2007 20:16:08
 Re: Super A water pump in reply to Philip Jenkins, 02-22-2007 12:18:49
Yes. It'll bolt right up. Just be careful about running the belt clearances...I needed two gaskets to line up straight. I didn't add a thermostat, or anything else. Simple bolt-up job. Mike
Vern
02-22-2007 15:14:08
The 113ci engines did not have, nor do they need, water pumps if the cooling system is in proper condition. The thermosiphon systems were pretty much fool proof as long as they had water in them. Occasionally the radiator & maybe the block need to be flushed of rust & scale. Note; Steam from the radiator does necessarilly mean that something is wrong. They thrive on that.
Vern
