Tractor Talk Discussion Forum
TRYING AGAIN! McCORMIC B275 Petrol
Tim Robinson
02-17-2007 11:53:37
Hi All,
Having to post this again due to the mess up the site has made of my original post. I am trying to find out where I can find an ignition coil for the above tractor, or if I can use any 12v coil. I know that the tractor has a positive earth so that should not make any difference. PLEASE HELP!!!!
Tim
janicholson
02-17-2007 12:59:59
 Re: TRYING AGAIN! McCORMIC B275 Petrol in reply to Tim Robinson, 02-17-2007 11:53:37
Assuming a 12 volt tractor, you need either a 12v coil with no external resistor required. You can also use a 12v coil with an external resistor required along with the ballast resistor from a mid 1960s GM car. (a white porcelin block about 2.5"X5/8"X5/8" with tab connectors on each end. The resistor is connected to the wire going to the ignition switch on one end, and the coil terminal that is not attached to the distributor/points. The coil polarity does matter. Attach the neg term of coil to dist if Neg ground, and pos of coil to dist if pos grond. If your tractor has a four terminal solenoid, and a ballast resistor is used, the I terminal of the solenoid is attached to the coil side of the ballast resistor. Long, but I hope complete info. JimN
Tim Robinson
02-17-2007 16:22:10
 Re: TRYING AGAIN! McCORMIC B275 Petrol in reply to janicholson, 02-17-2007 12:59:59
Jim,
Many thanks for your detailed post.
Donnie Baker
02-17-2007 12:21:45
I can't think of any reason why you couldn't I have used regular automotive coils on other sizes of Farmalls with no problems, I gotta go
