Tractor Talk Discussion Forum
Farmall 300 oil pump...
Horsedoc
02-17-2007 07:17:08
Doing a complete overhaul of 169 I-4 300 Farmall engine and full restore of tractor....I have found everything I need for the overhaul except...A new oil pump (retired part from case)...and new push rods for under $76 dollars a piece. I have checked everywhere....Does anyone know where I can get a new pump or a rebuilt one or cheaper push rods? Any help would be appreciated.
Greg_Ky
02-17-2007 13:11:26
 Re: Farmall 300 oil pump... in reply to Horsedoc, 02-17-2007 07:17:08
Contact Mark Melling at the link below. He should be able to make your push rods but he will have to know the diameter, length, and type of end. Also he may be able to help with your oil pump parts.
Janicholson
02-17-2007 07:56:52
The whole oilpumps have been a continuing topic on the IH Farmall forum above for years. There are (evidently) none. Bushings in the existing housing can be installed, the endplate can be flat polished, and new gaskets can be used to clearance the end play of the gears to about .0005 to .001. Some NOS gears are available. JimN
