Tractor Talk Discussion Forum
hey hillbillyOH!
dds-inc
02-16-2007 18:16:42
Farmall Cubs are POSITIVELY GROUNDED!!!! The way that you had the positive cable going to ground is 100% ORIGINAL!! You will mess up your generator and voltage regulator by having it hooked up the other way around!
I wanted to tell you this because in your other post, you were confused by the other people! You need to put that cable that goes to the ground BACK on the POSITIVE lead!!
hillbillyOH
02-17-2007 05:02:49
 Re: hey hillbillyOH! in reply to dds-inc, 02-16-2007 18:16:42
Thanks, dds. It took a while to sink into this thick skull of mine, but I think I now understand most of the 6-volt, positive-ground concept.
It was very counter-intuitive for someone raised on 12-volt, negative-ground systems. :)
hillbillyOH
02-17-2007 04:59:48
Thanks, dds. It took a while to sink into this thick skull of mine, but now I understand the whole 6-volt, positive-ground thing.
I guess I just found it all very counter-intuitive at first. :)
Bob
02-16-2007 19:39:39
dds,
What was there in the other thread to confuse him?
I don't see where he was told to reverse his battery cables away from the (+) ground setup his cub is supposed to have.
And, many of us told himit was unnecessary to disconnect the battery, at all, thereby avoiding the problem altogether!
huntingreen
02-17-2007 19:22:56
 Re: hey hillbillyOH! in reply to Bob, 02-16-2007 19:39:39
third party image
this is a test
huntingreen
02-17-2007 19:26:11
 Re: hey hillbillyOH! in reply to huntingreen, 02-17-2007 19:22:56
third party image
2nd test
