Tractor Talk Discussion Forum
jd 265 loader on a jd 2940
audie
02-13-2007 14:36:51
i have a jd 2940 open station tractor and have a line on a jd 265 loader. Does anyone know if this will fit and if they make mounts for it?
thanks audie
audie
02-13-2007 16:05:23
 Re: jd 265 loader on a jd 2940 in reply to audie, 02-13-2007 14:36:51
thanks for the info guys
Glen in TX
02-13-2007 15:50:01
Yes the 265 loader will fit your 2940 and 265 loader has the extra clearance for MFWD models also. JD tractor and loader compatibility charts showed the 265 loader was recommended for tractors from a 2840 up to a 4440 with HFWD or 4450 2WD. There wasn't a 260 loader then and the 245 loader was only recommended for up to a 2640 model. You can find out about mounting brackets in the JD online parts catalog by entering 265 and find all options there for loader brackets. A 148 loader also with right brackets on a 2940 2WD but doesn't have the extra height and length of the 265 loader for used with MFWD 2940 and larger tractors.
Glen in TX
02-13-2007 15:55:54
 Re: jd 265 loader on a jd 2940 in reply to Glen in TX, 02-13-2007 15:50:01
You need the utility tractor mounting frame for it to work as row crop frame only fits row crop 4050-4450 tractors.
JonMN
02-13-2007 15:37:27
I have a 265 loader on a 3155. I think the 260 loader went with the 50 series. You may want a 245 loader on a 2940. Call a John Deere dealership and ask for sure.
ben brown
02-13-2007 15:20:18
if i am not mistaken the 40,50,55 series tractors need a full fram mount. from rear axle to front of tractor the transmission housing was not made to with stand a total front fram mount loader.
