Tractor Talk Discussion Forum
ford 6.0 powerstroke block heater?
ole farmall
02-13-2007 11:17:43
I was just reading a post a few days ago about diesels starting up in cold weather...my dad has a 03' ford powerstorke 6.0 and couldent find the block heater anywhere..even in the manual..just wondering if anyone knew where it was...also if its cold(20 and below) when you sart her up(after the glow pulg sign goes off to show that they are heated up) she sputeeres and missses the first couple of seconds..is this normal or are the glow plugs bad...its got stright pipe,cold air intake and a superchip..but when she warms up no truck can get in her way..shes pretty bad!!
buickanddeere
02-14-2007 10:27:22
 should be using the blocker heater even if it will in reply to ole farmall, 02-13-2007 11:17:43
Even if the engine will start in freezing weather. You are doing your truck and your pocket book a favour by plugging in the block heater no matter if it's gas or diesel. The engine burns less fuel, suffers less wear and the windshield clears immediatley. And starting an engine and letting it idle to "warm up" is the dumbest thing since peeing into the wind.If electricity is avaliable to plug in.
Don Wadge
02-14-2007 11:05:11
 Re: should be using the blocker heater even if it in reply to buickanddeere, 02-14-2007 10:27:22
You got that right. Amen.
tractorbug
02-14-2007 08:15:06
 Re: ford 6.0 powerstroke block heater? in reply to ole farmall, 02-13-2007 11:17:43
Did a little more research,To save face FORD (back peddal)The destination of there diesel trucks has alot to due if you get the heater cord,they tell me the colder state's were the trucks r sold have the cords,Oh well anthything to save a buck.(I guess it doesn't get cold here in N.J.).
cant wait
02-14-2007 06:50:24
well we will just have to see about the new 6.4 pwrstrokes they are supposted to be pretty bad, i hope ford has improved
Andy In IL
02-13-2007 18:45:26
I work for Ford, I know how you guys feel about them I'm the same way. I already told my boss that the next one is a Dodge. The block heaters come standard on all diesel 6.0(wait a min.let me finish here!) the cord does not come standard, when you order a truck and want the block heater you are just buying the cord. I ordered a truck in 05 and didn't order the heater since I never had to plug in the 99 dodge I had. Boy that is a diffenrt story with po strokes I have to plug my in when it hit 25 degrees here. I had to buy the cord to put on my 6.0 which hooks up above the starter on the pass side and the cord winds around the fram to the front bumper on the riight side. Makes a little differnts too
tractorbug
02-13-2007 15:47:35
Hi,
Believe it or not !! This was one of the items FORD cut back on as standard equipment on there DIESEL ! trucks.It is now a 100.00 (part) option !! I was a little P.O. when i laid down 50,000.00 for a new 06 f-350 crew cab diesel Kingranch (with all the options).Then they said i would have to purch.the part !!!!! !! It will come back to bite them,wait till NISSAN / TOYOTA ETC.. START MAKING LARGER TRUCKS WITH DIESEL MOTORS. Im done with the Ford product and the way they treat there customers !!! Maybe the guy who decided to due away with heater cord got a raise,But i assure you,he dosen't give his kids COOKIES WITH OUT THE MILK !
no tools
02-13-2007 18:23:10
 Re: ford 6.0 powerstroke block heater? in reply to tractorbug, 02-13-2007 15:47:35
Well your just all tore up about the ford.
we have two new ones here 06-6.0 fresh off the lot with the heaters on them.The best part is you don't need thing.
Mydeere
02-13-2007 14:19:25
Don't know about the early 6.0's but on my '06, I had to order the heater when I ordered the truck. No longer comes standard, it's now an option. My 7.3 came standard with the block heater.
ole farmall
02-13-2007 14:24:28
 Re: ford 6.0 powerstroke block heater? in reply to Mydeere, 02-13-2007 14:19:25
i found it its right where you guys said at the tow hook..thanks alot
-Ryan
Jubilee johnny
02-13-2007 14:00:05
My 03' 6.0 plug is on the RIGHT side by the tow hook and my 03' 7.3 is on the left side by the tow hook.
Allan In NE
02-13-2007 12:07:13
Tucked in behind that left tow hook. Kind of a stinker to find. Yep, they sputer.
Allan
nickg
02-13-2007 11:20:45
Block heater on my 04 is on the passenger side bumper right next to the tow hook. Yes it is normal to have a little spit and sputter when its cold.
