Tractor Talk Discussion Forum
Restoring a Massey Harris 44 with a 6 Cyl.
beperson83
02-12-2007 08:48:04
Is there a way to check if the engine is froze? I cant start it becuase the carb is junk and the battery is dead. I've tried rebuilding the carb a couple of times, but everytime I get a kit, its missing the one part I need. But I want to know if the engine is stuck or not.
msb
02-12-2007 19:12:53
 Re: Restoring a Massey Harris 44 with a 6 Cyl. in reply to beperson83, 02-12-2007 08:48:04
If its a 44-6, then put a large pipe wrench on the transmission input shaft and see if you can turn the engine over that way.
Aaron Ford
02-12-2007 17:35:54
In addition to the other comments, I would like to add that rolling the engine over by hand, then by the starter (if equipped) in short bursts without spark plugs or fuel is an excellent way to be sure oil is delivered to all engine components prior to putting a fire in her. I even went as far as using the starter to ensure I had oil pressure prior to the start. It can even warn of impending trouble prior to catastrophe. Tight spots, noises, and other problems can be sorted out before it causes a major breakage. HTH
Aaron
Jim Johnson
02-12-2007 09:03:15
Put it in high gear and rock it back and forth, That will tell you real quick. Jim
mike a. tenn.
02-12-2007 09:06:57
 Re: Restoring a Massey Harris 44 with a 6 Cyl. in reply to Jim Johnson, 02-12-2007 09:03:15
hmmmm jim...didn't think of that one. he still might wanna pull the plugs first and squirt a little oil in each cylinder.
mike a. tenn.
02-12-2007 08:58:39
...only way i know of without at least dropping the oil pan, is pull all your spark plugs out so there's no compression and see if you can crank it over by hand.
-mike
