Tractor Talk Discussion Forum
Classic Ford F100
Rich Griffin
02-10-2007 06:40:44
I am rebuilding a original v-8 engine out of a 1954. I need the engine specs:size,bore,stoke,torq values,valve setting,tune up,etc,etc,etc, I posted this on Classic Trucks but got nothing to what I am needing. Can some one help out as I can"t find any books that go back that far. Thanks
gene bender
02-10-2007 15:54:20
 Re: Classic Ford F100 in reply to Rich Griffin, 02-10-2007 06:40:44
You say it is original then it would be a 239 ci in
1941 farmall a boy
02-10-2007 11:40:08
I have a 1971 ford f 100 custom and the long bed and the 360 engine i get about 8 mpg not good when it takes the 97+ for gas lol. Parts are not to cheep have you try"d www.lmctruck.com thay have some good stuff.
Old Magnet
02-10-2007 07:44:08
Get yourself a copy of "Hemmings Motor News" the bible source for old vehicles. You can find anything you need for the F100. Better availability of parts now then when they were new.
BLW
02-10-2007 07:24:35
bore & stk 3.5000 X3.100 ci 239/ comp ratio 7.20 130 hp 214 torque--plugs 35--pts 15--ign timing 3 degrees valves int and ex both .019 hot and cold
Billy NY
02-10-2007 06:51:22
Did you try the ford truck enthusiasts site, there's quite a bit going on there for these old fords. If that V-8 is a Y-block, there seems to be lot of parts on E-bay, I've seen brand new heads still in the wrapper etc.
