Tractor Talk Discussion Forum
Pulled the engine last night.....pictures included
wagsw900
02-08-2007 18:26:18
Three broken valve springs lead to pulling the head. Found all kinds of coolant sludge in the head and block. I dropped the pan and pulled a rod cap. It was just started wearing into the copper. So at that point I figured to rebuild the engine. Took the block crank and camshaft up to the local engine machine shop to have things checked out. the biggest task at hand is getting the block boiled out.
third party image
third party image
third party image
third party image
third party image
third party image
third party image
ejr-IA.
02-09-2007 06:59:19
 Re: Pulled the engine last night.....pictures incl in reply to wagsw900, 02-08-2007 18:26:18
How are the counter bores where the o rings go? Hope their not pitted to bad.I had to have new sleeves put in the counter bores on one of my Olivers.Have used jb weld on small pits.
David in Wales
02-09-2007 05:56:08
Hi there;
Looks as though you know what you are doing - hurry and finish. Then you can come over for a vacation. We can show you the sea & mountains, and some different farming & castles.
P.S. dont forget to bring your tool box over - I've got a 1961 Fordson Super Major that needs the same treatment ! LoL
Cheers David
TomTX
02-08-2007 19:03:28
What you are dealing with is one of those guys that says "if it aint broke don't fix it". Some people just do not do any maintenance, like changing the coolant, using top quality oil, good filters, etc. Glad to see you are doing a real "rescue" on the ole girl. How about the clutch, pressure plate, throw out, etc. gonna fix that too?? Tom
Mike M
02-08-2007 18:42:18
Looks like your ready to drop a 5.9 cummins/dodge in there !
Raleigh
02-08-2007 18:31:31
Boy!! what an affull amount of sludge build up in the water jacket!! Is this NORMAL???
What kind of a tractor is this? An Oliver?
wagsw900
02-08-2007 18:52:34
 Re: Pulled the engine last night.....pictures incl in reply to Raleigh, 02-08-2007 18:31:31
1951 Oliver 77. Purchased from the original owner two months ago.
jmixigo
02-08-2007 19:36:29
 Re: Pulled the engine last night.....pictures incl in reply to wagsw900, 02-08-2007 18:52:34
Consider:
A in the 50's most farmers followed the proceedure of drain in the fall an fresh water in the spring. Unless it ran hot, then what ever water was available got added.
B you are, most likely, looking at places that ain't seen daylight since 1951.
C your rebuild will prolly last another 56 years.
Not too bad, not bad at all really.
The Preacher
02-08-2007 19:50:34
 Re: Pulled the engine last night.....pictures incl in reply to jmixigo, 02-08-2007 19:36:29
Looks like a great opportunity to do some painting.
ebbsspeed
02-09-2007 07:12:17
 Re: Pulled the engine last night.....pictures incl in reply to The Preacher, 02-08-2007 19:50:34
One thing I'd recommend is that you use a longer length of chain bolted to the block. You're putting a tremendous amount of loading on both the block and the chain when you have it at such a wide angle as you do. That or move the two ends of the chain closer together, maybe instead of hooking at the rear of the block you could move that bolt to one of the holes between cylinders #5 & 6.
Wayne H
02-09-2007 17:03:45
 Re: Pulled the engine last night.....pictures incl in reply to ebbsspeed, 02-09-2007 07:12:17
That's the first thing that came to me also, you need a longer chain on that thing or put some angle iron on that lift to spread the load out some. You might be putting a lot of load on those bolts in a manner they never planned on...
