Tractor Talk Discussion Forum
743 unsteady steering levers
jedshed
02-08-2007 08:30:20
when i take my hands off the levers she want to go bye herself "wait a minute my wifs lie that too" any ways im not sure how to go about fixing it .the guys at bobcat say theres a trick to it.Any thoughts??
135 Fan
02-08-2007 15:45:10
 Re: 743 unsteady steering levers in reply to jedshed, 02-08-2007 08:30:20
Do you have a double u-joint connecting the engine to the hydrostatic pumps? I was told that if it isn't greased or goes bad it will cause steering problems. Some of the double u-joints can't be greased. The book on mine (Thomas) says to grease every 8 hours but even the dealer said every oil change should be fine. The newer Bobcats have the engine sideways and use a belt drive. There might be an adjuster to center the steering levers. Hope this helps. Dave
jedshed
02-09-2007 07:35:08
 Re: 743 unsteady steering levers in reply to 135 Fan, 02-08-2007 15:45:10
thanx ill look inti this
JCSinGA
02-08-2007 11:55:59
The steering is off center, usually requires installing new bushings in the pump levers and spring plate then re-center the levers at neutral. Theres no trick to doing it but it is tricky.
