Tractor Talk Discussion Forum
hytran looks like ice-cream
circus
02-07-2007 19:31:11
Hytran looks like ice-cream. In the cold weather the moisture in the gear oil of my Leyland prevents the hydraulics from working. The manual calls for motor oil. Changed the 16 gal. of oil ($$$!) which became contaminated at the first cycling of the loader. Any ideas?
Don-Wi
02-07-2007 23:59:34
 Re: hytran looks like ice-cream in reply to circus, 02-07-2007 19:31:11
Disconnect the return hoses next time and drain it straight into a bucket (or 2), then re-connect them. That should get most of it out. You can drain the lines ahead of time toofor the lift side to get that extra little bit out.
Donovan from Wisconsin
I'm guessing you have other IH tractors and that's why you're using hy-tran?
We do it too, exept we run Massey and Oliver, so we run Perma Tran III in ours.
circus
02-08-2007 00:22:05
 Re: using motor oil in reply to Don-Wi, 02-07-2007 23:59:34
didn't realize hytran was a brand name
Don-Wi
02-08-2007 00:39:57
 Re: using motor oil in reply to circus, 02-08-2007 00:22:05
No biggie, IH has HyTran, Massey has Perma-Tran III, and I forget what Deere has. Don't know about the rest.... Its all good though.
It's good for anything that uses the same oil for hydraulics and the transmission oil, and can be used in many others for just hydraulic oil purposes.
Michael price
02-07-2007 20:30:04
You could take the hoses off the cylinders and drain it all out of them but you wont get it all out but you can get alot of it out of there and maybe save a oil change.
john cub owner
02-07-2007 20:10:47
you need to flush it, maybe a couple of changes. Not what you wanted to hear I know. Remember, there is quite a bit of oil stored in the tops of the 2 way cylinders, even when they are retracted. You need to get it out too.
