Tractor Talk Discussion Forum
(OT) Forklift Lifting Ques.
doogdoog
01-27-2007 00:25:49
Aloha, The forklift sales rep. told me that I could lift the front two wheels off the ground by using the mast tilt. I tried it and couldn"t get to lift the front tires off the ground because the carriage also went up. My forks are 42" long so I was wondering if it works for 48" forks. Any thought to this?? TIA
Mahalo,
doogdoog
doogdoog
01-27-2007 22:44:18
 Re: (OT) Forklift Lifting Ques. in reply to doogdoog, 01-27-2007 00:25:49
Aloha, Yes, it is a regular forklift and thanks for all the replies and I will try the block method.
Mahalo,
doogdoog
tony weir
01-27-2007 03:31:23
Fix lift trucks take 4x4 block of wood tilt back all the way put wood under mast rails tilt foward should lft about 2to4 inch use only hard wood not steel or soft wood hope this helps.
willie in mn
01-27-2007 03:10:05
Pitch is right. Have done that many times. And by placing blocks under tires & repeating can lift as high as you want. Gets a bit wobbly when jacked up over 18 inches this way.
Work Safely
Willie
Pitch
01-27-2007 01:52:57
Your talking a regular forklift right? I haven't been around forklifts for 15 years but you can do it. Lift it just enough to change a tire or put on chains. Raise your forks enough to get them out of your way and tilt back . jam blocking under the bottom of each lower mast section or under the side you want up and tilt forward . Should lift 4 or 5 inches.
