Tractor Talk Discussion Forum
checking generator
n8terry
01-25-2007 17:12:37
I have a 12 volt generator that I bought at salvage yard. Is there a way that I can bench test it to see if its putting out?
This is a generator, not an alternator.
What I was hoping to do was put it in a vice and spin it with a drill, will this work?
Grampa Leon
01-26-2007 09:45:05
 Re: checking generator in reply to n8terry, 01-25-2007 17:12:37
Clamp generator in vice,as you mentioned,apply 12 volts to terminals,gen. whill "motor" in direction of its design,this is how a rebuilder
tested their work [did this for eons].
Glen in TX
01-26-2007 08:59:11
Some generator info:>Link
>Link
Gary from Muleshoe
01-25-2007 19:13:47
If you have an Auto Zone or a NAPA patrs store near by, they will generaly check them for you at no charge.
Janicholson
01-25-2007 17:22:25
Yes if!!!
There are three possible generators, and unless we know which, setting up a test would be unlikely. We need to know what it came off of, what numbers are on it, and model/brand. There are three brush generators, two brush "A" type and two brush "B" type systems. Checking them is way different. JimN
