Tractor Talk Discussion Forum
(OT) 1990 2ton Yale Forklift Incher Question.
doogdoog
01-24-2007 16:19:47
Aloha, I have a 1990 Yale 2 ton forklift and have a question on the "inching control" ckt. From my understanding, when the brake is partially applied, the clutch pack is suppose to slip a little to inch into the load and when the brake is depressed all the way, the trans. fluid is supposed to be diverted to the sump (no forward movement). Ok, I was on a slight incline (forks facing uphill) with the selector in the forward position (drive) and had the brake depressed all the way down and when I slowly let it out, the forklift started to roll backwards. It seems that the inching is not working correctly but when I let the brake out further (all the way out), it goes forward (which is normal). Could the inching valve be only half working?? TIA
Mahalo,
doogdoog
MSM
01-24-2007 16:36:45
 Re: (OT) 1990 2ton Yale Forklift Incher Question in reply to doogdoog, 01-24-2007 16:19:47
That is not an inching pedal. It is a trans disconnct/brake. When holding it down,it allows you to hold the machine still while revving the motor to shift, raise or tilt the forks without changing gear position into neutral.It should have a second brake pedal which just applies the brakes or a switch to disable the trans disconnect so you can work on a grade and hold position.
doogdoog
01-24-2007 21:05:48
 Re: (OT) 1990 2ton Yale Forklift Incher Question in reply to MSM, 01-24-2007 16:36:45
Aloha MSM, Thanks for the reply but there is only one brake pedal so right now I am using the parking brake so I don't roll back. I could live with the way it is working now, but if I am on an incline and something is very close behind me, I have to use the hand brake so I don't roll backwards before the trans engages.
Don-Wi
01-25-2007 01:38:36
 Re: (OT) 1990 2ton Yale Forklift Incher Question in reply to doogdoog, 01-24-2007 21:05:48
Maybe my answer is different because it ain't mine that I drive, but drive it w/ both feet and hit the gas before letting off the brake pedal. It aint fun till it's an old Allis Chalmers and it's got the clutch too..... I fortunately I don;t have to drive that one anymore but I was on inclines every now & then, never had any problems with it.
Donovan from Wisconsin
doogdoog
01-25-2007 03:42:48
 Re: (OT) 1990 2ton Yale Forklift Incher Question in reply to Don-Wi, 01-25-2007 01:38:36
Aloha Don-Wi, If I did that (hit the gas) with my auto trans and released the pressure on the brake pedal, it would lurch forward and probably crash into something. LOL I remember driving a Hyster forklift a long time ago and it had a clutch and torque converter so it was like an automatic.
Mahalo,
doogdoog
Don-Wi
01-26-2007 16:54:32
 Re: (OT) 1990 2ton Yale Forklift Incher Question in reply to doogdoog, 01-25-2007 03:42:48
Hmmm... The Yales at work must be a little different because they only lurch when you first put them in gear.
The Allis was at the last shop I worked at. The mast sank really fast, and it leaked brake and hydraulic fluid all over the shop. That one was a straight clutch/gear transmission w/ a high/low, pull up for high and down for low... They always tended to grind some once in a while....
No tourque converter on that baby....
