Tractor Talk Discussion Forum
Spark Plub ? for Allen
EUG1206
01-16-2007 09:57:23
Allen, I have a Farmall 300 I am restoring, getting down to the end and want to put in some new plugs and wires in. I recall you had some issues with a certain plug brand but not sure which one. Any reccomendations?
Thanks for your help. I enjoy reading your posts
Glen in TX
01-16-2007 12:38:18
 Re: Spark Plub ? for Allen in reply to EUG1206, 01-16-2007 09:57:23
Metallic core wires to get more fire to the plug than carbon core auto wires and keeping engine as warm as needed and carb lean as you can. The Autolite 386 & 388 are resistor type plugs and shouldn't be run with magnetos but okay for battery distributor but you'll get more fire to the hole with non resistor types. Following are all non resistor plugs. Champion D18Y was originally recommended but Champion D21 & D23 are hotter. Other good ones are Denso L14-U, Autolite 3116 and AC C88 or C88L.
ejr-IA.
01-16-2007 11:51:59
386 Autolite plug would be good for it.
Allan In NE
01-16-2007 10:16:36
Eugene,
I'm just not much of a "gasser" tractor guy. Just don't understand the darned old things if they aren't diesel.
I finally ended up using Champion D-21s. Couldn't keep the Auto-Lites from carbon fouling. 'Course, I subsequently ended up doing a volve job on the old heifer too, so maybe that had something to do with it.
Allan
Carp
01-16-2007 10:11:22
Well, I am not Allen, but I would recommend Autolite 3116 spark plugs. They generally work the best in my farmall's.
