Tractor Talk Discussion Forum
Belarus 250AS
Newshound
01-15-2007 21:17:20
I just bought a used Belarus. The guy said it's from the early 80's and that's about all I know about it. It has a 2 cylinder air cooled diesel engine that starts right up but just don't have the power to pull itself up a small incline much less a hill. I noticed that when its running, oil comes out the dipstick tube. One friend said that's blowby from the pistons and I need a ring job. Another said a diesel starts off compression and if it has enough compressing to start, the rings must be good and something is stopped up to make the blowby go to the crank case. Anybody got any opinions on either of those opinions?? Thanks.
phil25
01-16-2007 03:24:00
 Re: Belarus 250AS in reply to Newshound, 01-15-2007 21:17:20
Just a few ideas from the book of russian,lack of power is most common to be the fuel system ie filters/injector[s]/pump parts sticking, would expect some of that if it has been sitting a few years?
oil coming out is listed as too high a oil level in sump, have you changed the oil? there should be a "B" mark on the dipstick as full indicator.
Also if the fuel pump shaft seal is leaking, fuel can get into the base and raise the oil level, so maybe crack the drain plug to check if fuel or oil comes out first?
Also the stuck ring[s] is mentioned as possible pressure source into the base, maybe worn[hours???]or carbonized from easy use also found around the vaves if carbon is built up.
Parts are available both canadian and amercian, just have to look a bit, ie "fawcett tractor" in Ontario check for a web site for Belarus.ca
hope it helps
Hard Knocks
01-16-2007 03:04:53
Hope you didn't pay much
low budget
01-16-2007 02:52:06
Could have compression on one cylinder and none on the other. That would explain it starting and also the lack of power and the blowby. I think you can get parts from some outfit in Canada. I'll keep my opinion of Belarus to myself but good luck.
