Tractor Talk Discussion Forum
6-volt Generator Repair
AWB
01-15-2007 18:10:05
Where can I send a Delco generator to be rebuilt? Or, where can I obtain a rebuilt armature and field coils for a 6-volt delco generator? Thanks.
Bob with B allis
01-16-2007 05:32:14
 Re: 6-volt Generator Repair in reply to AWB, 01-15-2007 18:10:05
Mine was chewed up that bad. Took it to a starter alternator shop about 60 miles away, cost $ 145.00 to get it fixed. Could have bought a reman cheaper. Wish I had just converted it to alternator and went to 12 volt system instead.
dan hill
01-19-2007 06:09:48
 Re: 6-volt Generator Repair in reply to Bob with B allis, 01-16-2007 05:32:14
Some shops just charge too much.Neighbor had an old ford starter that was giving trouble.Called a big shop, got a 100.00 quote.I put new brushes in it and gave the commutator a light turning,the bushings and drive were ok.Charged him 10.00.Was in an electric motor shop. Labor rate was 70.00 per hour.Was hunting for a magneto cap, a shop in Maine gets 93.00 per hour labor for mag work.Tried to get a brush rigging for a 96 ford starter. shop said 40.00.Got one for 16.50 including priority mail.
AWB
01-16-2007 06:51:49
Bob: Point well taken May end up doing as you suggested. Thanks.
John T
01-15-2007 19:48:48
If it reallyyyyy y? needs BOTH a new armature plus field coils, it may be wiser to go ahead n buy a whole new rebuilt unit n be done with it. Often its only a set of brushes n maybe a bushing n have the commutator turned is about all they usually require. However if the bushings were so shot the armature was dragging it may be shot and they arent cheap. If the armature isnt shorted to ground and passes the smell test it might be fine n all you need is brushes, maybe a bushing???
John T
AWB
01-16-2007 06:54:41
 Re: 6-volt Generator Repair in reply to John T, 01-15-2007 19:48:48
John T: Thanks for the suggestion. Buying a rebuilt to start with may be the best route to take. Thanks
Glen in TX
01-15-2007 18:47:00
Check your yellow pages for local alternator or starter electrical rebuilders or battery shops or try Kenneth at Classic here in TX.
AWB
01-16-2007 06:49:40
 Re: 6-volt Generator Repair in reply to Glen in TX, 01-15-2007 18:47:00
Glen: Thank you very much for the generator repair information.
wayne2
01-15-2007 18:21:02
Is it chewed up that bad?
