Tractor Talk Discussion Forum
1586 CAB BLOWER
jimmall
01-14-2007 12:28:17
MY BLOWER STOPPED WORKING. THE RADIO WIPERS WORK BUT BLOWER DOESNT WORK. THE CLUTCH ENGAGES WHEN AIR SWITCH IS TURNED BUT NO BLOWER. IS THERE A FUSE OR RELAY THAT NEEDS TO BE CHAANGED OUT. WHEN KEY SWITCH IS TURNED ON YOU HERE ACLICKING NOISE. NEED HELP. JIM
fixerupper
01-14-2007 18:36:47
 Re: 1586 CAB BLOWER in reply to jimmall, 01-14-2007 12:28:17
On my 1086 if the radio works, the relay is sending power to the cab, though that relay does fail once in a while. Sounds like a bad fan switch or motor. While you are up there on top of the cab, blow out the air cond. evaporator and heater core. Jim
TratorFxr
01-14-2007 12:40:25
Verify the cab solenoid is functioning with test light. If so, go to right hand step inside of rt hand door, inspect wiring harness disconnect. I have found the wires inside this disconnect become corroded causing your problem
Hope this helps!
Bob
01-14-2007 12:36:36
Check to see if there's power to the blower motor. (As well as "ground".)
If there is, the blower motor has simply failed.
IaGary
01-14-2007 17:33:02
 Re: 1586 CAB BLOWER in reply to Bob, 01-14-2007 12:36:36
As the others have said if the solenoid is working then it is the switch, blower itself or the wires inbetween.
I would start at the blower under the panel on top.
Gary
