Tractor Talk Discussion Forum
allis wd or wd-45?
hammerfer
01-13-2007 17:06:38
What I was assuming was a WD, might actually end up being a combination. Serial # 200937. Bolt on plate right side of engine. Straight shifter handle. The serial number is taken off the top of the transmission just forward of the shifter and also K-24-P3 was there. Any help? Thanks
hammerfer
01-13-2007 18:11:08
 Re: allis wd or wd-45? in reply to hammerfer, 01-13-2007 17:06:38
Thanks for your help with the location of the serial number. Still tough to see with the paint buildup. WD51271 is the number so that puts it at a 1950 WD. It took us 2 tries to load it a month ago, rear wheels locked up. 30 miles on a trailer and I rolled her into the garage, its almost like she didnt want to leave home. After a week of scraping thick rust out of the carb she runs like a champ. All I need now is power adjust rims and tires. Thanks for your help and thanks to this site.
wilman
01-13-2007 17:25:51
Serial number for a WD or WD 45 will be at the left brake cover or left axel housing. Should start with WD******.
old
01-13-2007 17:24:25
Bolt on side plate makes it a WD engine, stright shifter again makes it a WD. Serial number on a WD is on the left back side of the rear axle just below the brake cove plate. Now if the engine didn't have that plate then its a WD45 engine. If it had a curved shifter it could be either a late WD or a WD45 since the Wd the last year or so had the carved shifter also
