Tractor Talk Discussion Forum
clutch on jd 1020
walter wallace
01-11-2007 14:51:15
what would make tractor move with clutch petal down.tractor will still be pulling for about 5 or 10 feet.before it disingages or i hit the brakes.this does not happen every time the clutch is pressed.the fluid is at the level it should be.what should i do!
walter wallace
01-23-2007 13:16:53
 Re: clutch on jd 1020 in reply to walter wallace, 01-11-2007 14:51:15
used tractor several times after adjusting clutch.have had no problem with tractor wanting to keep going with clutch padle down.thanks for the advice from yal.had many suggustions and that is what i needed to get me going in the right direction.thanks again
buickanddeere
01-12-2007 16:26:00
When was the last time you greased the clutch?
walter wallace
01-12-2007 20:27:47
 Re: clutch on jd 1020 in reply to buickanddeere, 01-12-2007 16:26:00
didnot know you had to ,pedal i know about.how do you grease the clutch
buickanddeere
01-13-2007 14:19:22
 Re: clutch on jd 1020 in reply to walter wallace, 01-12-2007 20:27:47
The clutch lubrication location is pictured in your operator's manual. If it dries out the clutch will stick in the engaged position. 1-800-522-7448 if your's has disapeared. May as well get the service manual at the same time.
Mike M
01-12-2007 05:20:25
I'd start by adjusting the free play and then if it still does it adjust the clutch by the book. You have to read very carefully as there are many different clutches in those and adjust differently. If it still does it after everything is in adjustment I'm guessing some oil or grease or rust makeing it stick. You may be able to avoid splitting it by putting it in high gear engine about full throttle then let the clutch out and hold the brakes. It should slip and burn off some of the junk and then it may work good again. DO NOT do this too long as it will get hot and if too hot may warp something which could allready be another reason it acts like it does. A warped clutch plate can act like that too.
msb
01-11-2007 18:42:31
What clutch/PTO set up does it have? Does it have a PTO? Dual stage clutch? Hi/lo Dual stage? Hi/Low Independent live PTO? Dual stage w/ reverser?
walter wallace
01-11-2007 20:35:40
 Re: clutch on jd 1020 in reply to msb, 01-11-2007 18:42:31
i do have a pto,hi/low independent live pto,meaning that the pto has to be ingaged by a lever but works off the clutch,it also has hi / low range trans.as you can tell i'm trying to learn about my tractor.
msb
01-12-2007 08:26:20
 Re: clutch on jd 1020 in reply to walter wallace, 01-11-2007 20:35:40
Didn't make myself clear.Sounds like you have a two stage cdlutch.Push it down part way to stop the ground travel.Push bit down all the way and the PTO stops.IF that is what you have then it sounds like one of the clutch fingers is out of adjustment. I could probably walk you through the adjustment once we decide for sure that is the setup you have.Repost tonight and let me know.
walter wallace
01-12-2007 10:29:10
 Re: clutch on jd 1020 in reply to msb, 01-12-2007 08:26:20
yes i do have a two stage clutch,try what you said and pto stops with clutch fully down.used the tractor about 2hours today with no trouble.i did slip the clutch in hi gear for short time.thinking may some grease or something was on it.can you adjust clutch or do you have to have a pressure gage to do that.
msb
01-12-2007 19:23:33
 Re: clutch on jd 1020 in reply to walter wallace, 01-12-2007 10:29:10
No pressure gauge for that, but it sounds like you may need to reset the finger heights.I have the page out of the service manual right here if you want it and I can figure out how to scan it and post it. Its a fairly easy proceedure to do.Let me know amd I'll try to post it.
walter wallace
01-12-2007 20:44:46
 Re: clutch on jd 1020 in reply to msb, 01-12-2007 19:23:33
i have an i&t shop manual that show how to do that.you say it fairly easy to do.
Mike M
01-12-2007 17:54:42
If it set very much it may of had some rust on it ?
At the very least pick up a copy of an I & T shop manual. Rural King ,TSC,or even a JD dealer may carry them. Very cheap and give you the adjustment proceedure on the clutch and other stuff.
walter wallace
01-12-2007 20:51:58
 Re: clutch on jd 1020 in reply to Mike M, 01-12-2007 17:54:42
thank you, i have the i&t shop manual just need some place to start and you people have helped very much.i thought the tractor may be needed to be split.which i could not do.i will try these adjustment first.thanks
