Tractor Talk Discussion Forum
Where to buy Tractor Splitter Stands Reasonable?
Looking Cen IL
01-11-2007 05:28:55
Does anyone know where you can buy a splitter stand for 4430,4020s? Did a google search and found nothing of value. Thanks.
Cliff Neubauer
01-11-2007 09:31:05
 Re: Where to buy Tractor Splitter Stands Reasonabl in reply to Looking Cen IL, 01-11-2007 05:28:55
third party image
I built this set several years ago using some heavy side crank implement jacks, a pair of 2,500lb capacity caster wheels and some 3/8" plate for about a $100. We've used them to split everything from our Super H to our 5488 with no problems. The caster wheels are a mixed blessing, they let you roll the front half of the tractor anywhere you want but it takes two people to push it in a straight line.
JMS/MN
01-11-2007 07:58:26
Another HM idea is to use Bulldog jacks- one on each side, heavy side plate to bolt to tractor frame, tie bar near the bottom for stability.
MN Scott
01-11-2007 07:21:19
Cofer makes splitting stands. I made a set myself patterned off them. They work good and are universal. Click on link below picture.
third party image
RustyFarmall
01-11-2007 06:30:15
I worked for a Deere dealer back in the early seventies. We used splitting stands made by OTC. Owatonna tool corporation.
Mike M
01-11-2007 05:52:09
It is not too hard to make a set. Some flat steel plate drill holes to match frame holes weld on some square tubing for legs,large all thread and nuts for adjustable feet slid up into tubing.Bolt one on each side. Might be a good idea to fasten a brace between the two legs near the bottom so they can't kick out on a large tractor.
