Tractor Talk Discussion Forum
OT/ 460 BB compressioin
super_m
01-10-2007 13:59:41
i have a 85' f250 with a 460 in it.as far as i know the motor is stock and it has 120 pounds of compression,is that good or should it be higher?the truck has 136,000 miles.
the tractor vet
01-10-2007 20:06:01
 Re: OT/ 460 BB compressioin in reply to super_m, 01-10-2007 13:59:41
That ain't to bad for a smog motor . Just don't do like i did on one 460 i built used the old 72 CC heads and the old pistons from back in 69 the heads were off a 70 429 SCJ and i could not figure why i was having trouble cranking it over even with a 11000 RPM starter till we took a comp. test . I just grabed my old hold in gauge and got up on a five gallon bucket and stright armed the gauge in the hole and hit the remote and on the first hit she blew me off the bucket and the gauge read 275 , Nah that can't be wright so i tryed again and got blew off the bucket about that time a buddy walked into the shop and this boy is strong and i said hey Ron hold this gauge in the hole while i crank it over so he stuffs it in the hole and stright arms it and i hit the botton and BAM it shoves him off PLUS it put the rubber tip up over the nut on the gauge and the gauge is pegged at 300 Nah this can not be wright so i get my good screw in gauge out and we try agin now this gauge goes to 350 On the first hit it blows the O/RING out and pegs the gauge . Now this is a NO B/S story and there were several people there at the that time . I figured that she had good comp.
Janicholson
01-10-2007 17:12:40
With out the specs in front of me, I would say it is fine. From 115 to 140 is about normal. Is your gauge calibrated, check it against another to be sure. JimN
RustyFarmall
01-10-2007 14:22:27
Don't know what it should be, but 120# isn't bad. As long as all cylinders are fairly even, I'd just drive it.
