Tractor Talk Discussion Forum
It's not Allan's fault this time! : )
Matt Smith
01-09-2007 10:23:57
My old "swaybacked" garage has been needing some expensive TLC for some time. I figured since work gets slow this time of year, I'd go ahead and get the roof fixed. I'm also gonna add 3 courses of block to the walls so I'll have an inside height of 9 feet.
third party image
To do that, the old roof has to come off. Not just the shingles, mind you... Every piece of wood on this ol' thing is getting thrown in that borrowed grain truck. I just parked it down there the other day.
I should've known better than to open up a roof this time of year. Seems every time I have a roofing project, the weather takes a turn for the worse. The report is calling for an Arctic blast of air this weekend.
I guarantee you it's all my fault. : )
Aaron Ford
01-09-2007 12:02:49
 Re: It's not Allan's fault this time! : ) in reply to Matt Smith, 01-09-2007 10:23:57
I thought it was my fault. I left my project uncovered overnight for the very first time. Woke up this morning to over an inch of snow. Figured I jump-started winter...
Let's go Mountaineers,
Aaron
big hunter
01-09-2007 10:45:22
the last place I lived I had a 26 by 40 garage, was thinking about taking the whole roof off to make a second floor then put the roof back on. I was going to put some beams under the rafts then hook a crane to it, lift that sucker off. crane rental was $500 a day...in theory needed crane to lift off one day, then later back on...2 days and $1,000 versus about I don't know what maybe a month of tearing it apart then putting it back together...just a thought
big hunter
01-09-2007 10:47:36
 Re: It's not Allan's fault this time! : ) in reply to big hunter, 01-09-2007 10:45:22
sorry... end of story is I got married and moved...GOOD GRIEF
the tractor vet
01-09-2007 10:33:44
Don't stop at just 9 foot as next year your going to be standing in there and thinking darn i should have went just three more feet if not four.
Matt Smith
01-09-2007 10:49:47
 Re: It's not Allan's fault this time! : ) in reply to the tractor vet, 01-09-2007 10:33:44
Code only allows me to go nine feet with the size of the footing under it right now.
If I was building a pole barn, It would definately be twice as big as I thought I needed. : )
Don-Wi
01-10-2007 00:40:57
 Re: It's not Allan's fault this time! : ) in reply to Matt Smith, 01-09-2007 10:49:47
An idea I've got is raise it up to 9', but then where the overhead door would be, kinda frame that up so a 12' door could go in there. Then you'd be within the 9' limit but be able to drive that truck in with room to spare (atleast overhead anyway)
Just a thought, but it's worth a shot
Donovan from Wisconsin
Walt Davies
01-09-2007 12:41:54
Ain't that funny its just like the local Morons to think of some silly thing.
A pole barn with no footing can go as high as you want but if you put a footing in then you are limited to hight.
Walt
