Tractor Talk Discussion Forum
Bosch fuel injection pumps
Animal
01-03-2007 14:24:27
Is their a website I can go to for info on these? I have a 930 case that is not transfering fuel, I can bleed it off and start it, it runs until out of fuel, or is it fesable to put an electric fuel pump on these to transfer fuel? This tractor has set over ten years, I have cleaned the lines, put in clean fuel and have changed the filters, any help would be appreciated....
c hess
01-03-2007 17:51:02
 Re: Bosch fuel injection pumps in reply to Animal , 01-03-2007 14:24:27
Assume you mean the inline pump. Would be good to know model of tractor. But on any of them remove line to first filter an determine if there is a full stream of fuel -could be a pluged pencil filter in tank.Should have a full flow. An if you have a manual prime pump you can remove an take apart -there might be a bunch of dirt in it.Since you already changed filters there should not be any problem with them.Also dont know if 930 tractors had a (t) handle on top of double filters but if it has it needs to be turned tight clockwise.If tractor runs for short time an than stops there is a restriction somewhere .If you have no fuel pressure gage you should be able to feel pulses of small pump on short hose to final filter if running corectly.
