Tractor Talk Discussion Forum
loss of power on a Case-SC
heenk
01-01-2007 12:49:26
I"m unable to get my SC to run smoothly.By pulling of the spark cables by cyl #4 the rpm change very little if any pulling of # 2 the engine really goes down in rpm.It"s not the cables and mag.since I"ve changed the positions on the mag (moved all cables one position and also the setting) with no change.valves seem to have the right spacing.
What could it be?
wl in mi
01-06-2007 09:29:07
 Re: loss of power on a Case-SC in reply to heenk, 01-01-2007 12:49:26
check to see if you have a broken valve spring on #4 cyclinder.
ken in texas
01-01-2007 17:25:14
Sounds like you've checked about every thing.Might try this , check for vacume leak at intake manifold,could be enough to cause a miss .lol
ken in texas
01-01-2007 17:24:47
heenk
01-02-2007 20:14:03
 Re: loss of power on a Case-SC in reply to ken in texas, 01-01-2007 17:24:47
Hello Ken in Texas
You made me think and I removed the valve cover to see what is happening. Keep in mind that # 4 sounds like it runs at 50% when removing the wire when running but #2 has a push rod that"s bend So now I have to locate a new Pushrod anyhow thanks for your input
Paul Janke
01-01-2007 16:36:06
So far nobody has mentioned carburetion. Maybe a dirty or plugged sediment bowl or screen, fuel filter, something in the carburetor. On the ignition, make sure the points open the proper amount. They don"t run well when the points open almost not at all.
Glenn F.
01-01-2007 14:54:35
While it may have more horsepower if you overhauled it, I do not think low compression is your problem. 95-100 should run smoothly. Are you SURE you have the spark plug wires on correctly? Make sure you know which way the rotor turns, and recheck your firing order/plug wires. You may have two of them switched around. Also, are you sure your plug wires are good/carrying strong spark?
Glenn
HAPPY DEERE
01-01-2007 14:20:32
looks like a compresion loss in all 4 could just be a color problem look at the paint jobjust kiddin no i would try putting new rings in it if its that bad
heenk
01-01-2007 14:20:20
Forgot to mention has new plugs. Switched the cables and plugs around checked the compression and it's between 95 and 100 psi for all cylinders.
well
01-01-2007 13:28:14
could be a # of things sounds to me like its yur basic problem a fouling plug but, if its not that it could be from the way i understand what you have said just could be the cylinder with a hole in it or could be bad rings think i would change the plug first and go from there never know one of these guys on here will give you better advice im sure.
heenk
01-01-2007 14:12:10
 Re: loss of power on a Case-SC in reply to well, 01-01-2007 13:28:14
Forgot to mention checked the compression #1-100 psi #2-95 psi #3 100 psi # 4 95 PSI new plugs and switched plugs around.
heenk
01-01-2007 14:03:49
