Tractor Talk Discussion Forum
1941 A John Deere Govoner Problems
Rob Hartman
01-01-2007 07:40:12
Hi guys. I've been reading alot of your posts. I really get a kick out of Allen and Gary, you guys make my day. I've been having some trouble with my govoner. I have a 1941 A with a Power Block. I have totally rebuilt everything on this tractor. The only piece I did not replace in the govoner was the bronze collar that slides on the shaft. I cleaned it up with some emery cloth and it looks fine. I've done all the tricks with the linkage and my govoner is lazy. It has to really be under a load for it to come alive. It is slow reving up, and wants to overrev abit. If you stand on the brakes it will come on, if you put it on the dyno it will come on. I put 3-14's behind it and drop it in the ground and it just idles down but still pulls, the govoner is just not working. It pulls over 60hp on the dyno. I'm out of options on this if somebody has any ideas I sure would appriciate it before I have no hair left. Thanks
luckydog
01-01-2007 10:31:30
 Re: 1941 A John Deere Govoner Problems in reply to Rob Hartman, 01-01-2007 07:40:12
Rob-- Just a thought, on top of your gov. housing where your linkage is there is a gov. spring that is held to the gov. arm. Your spring is bolted to the arm with a bolt and a lock nut. Loosen that nut and make sure that the bolt is all the way in and tight then tighten the nut. If that bolt is alittle loose or not seated that may be your problem. Just a thought. Luckydog
Rob Hartman
01-01-2007 10:47:21
 Re: 1941 A John Deere Govoner Problems in reply to luckydog, 01-01-2007 10:31:30
Everything on this tractor has been apart and triple checked. The arm shaft has some play but I've seen some alot worse that run perfect. I tried putting a broken spring in front of the old one to give more pull but no change. Thanks for the reply.
