Tractor Talk Discussion Forum
Front pump coupling
NCcub
12-31-2006 16:51:32
I have a 1963 MF 35 with a front end loader. It has the front pump. Looks like the bearing went out in the Vickers Vane pump and the coupling got meesed up. The coupling is a Morflex 352. I found a couple of sites that sell the whole kit but I just need 1 piece of the kit. Does anyone know of a company where I can buy specific pcs. of the kit?
Thanks
Kerry
Bob
12-31-2006 21:52:06
 Re: Front pump coupling in reply to NCcub, 12-31-2006 16:51:32
What part of the coupling do you need... one of the outer "flanges", or the actual Morflex unit?
If the Morflex center unit is all you need, a local "bearings and drives"-type place can likely fix you up.
If you need one of the "flanges" or "spiders" that slip on the shaft, and bolt to the Morflex unit, check with a Massey (Agco) dealer.
NCCub
01-01-2007 10:06:44
 Re: Front pump coupling in reply to Bob, 12-31-2006 21:52:06
I need one of the outer pieces, has a 3/4" bore with key way. Found a kit with everything, just need this one piece if possibe.
Kerry
