Tractor Talk Discussion Forum
Building A Parts Tractor
Allan In NE
12-31-2006 14:19:51
Kinda workin' myself out of a job here and into another.
Gotta swap a couple of pulleys at the engine and put Gary's sheet metal back on and I'm 'bout done with one tractor.
Then, I 'spose the real work starts on this sad ol' feller. How warm does it have to be to paint outside?
Allan
third party image
klobru
12-31-2006 19:45:49
 Re: Building A Parts Tractor in reply to Allan In NE, 12-31-2006 14:19:51
looks like mothernature already has started painting the WHITE for you...
Wisconsin Cowman
12-31-2006 20:27:17
 Re: Building A Parts Tractor in reply to klobru, 12-31-2006 19:45:49
Usually 50 degrees outside to be painting.
No tools
12-31-2006 17:21:45
Allan
it aint none of my business but which pulleys do you have to change.
As far as painting outside well i have at 40 degrees just use fast dry reducer.
I know guys say it has to be above 70 but heck the can says 40-90 degrees.
The reducer is where its at.
Bill
Allan In NE
01-01-2007 03:10:45
 Re: Building A Parts Tractor in reply to No tools, 12-31-2006 17:21:45
Open station tractors used only one belt to drive the alternator and the water pump/fan.
A cab-equipped tractor uses two belts for the water pump/alternator and a third pulley groove on the water pump then pulls the compressor.
Also gotta change out the heater hose shut-off valves and then I think I can put the sheet metal back on, button 'er up and send it home. :>)
Allan
Don L C
12-31-2006 15:22:18
Pour the paint on from the can and quickly spread it with a pure brisel brush..... ..
RustyFarmall
12-31-2006 14:38:57
Go ahead and paint it. 'Course the paint will come off with the snow when the weather warms up.
Farmer in the Dells (WI)
12-31-2006 14:31:49
I think you can paint as long as the brush bends in both directions. As soon as it doesn't you have to turn it over to go the other direction but you better finish up soon.
KEH
12-31-2006 15:33:34
 Re: Building A Parts Tractor in reply to Farmer in the Dells (WI) , 12-31-2006 14:31:49
What do the directions on the can say about temperature? Hey, you have to get the snow off first anyway, LOL.
KEH
