Tractor Talk Discussion Forum
IH,JD,AC,etc
need info
12-31-2006 05:09:38
How does the gas Super M compare in fuel economy to the gas AC WD45 or JD 60 & 70 or Oliver Super 77? What is the drawbar hp and belt hp of each at max hp and rated hp? Is there a side by side data sheet that shows each test at Nebraska with info shown for every run the tractor was put through? Which of these tractor models does the best in each economy test. I know the tests are labeled like test H or test G etc. Thanks. Jack
Jim Johnson
12-31-2006 06:07:11
 Re: IH,JD,AC,etc in reply to need info, 12-31-2006 05:09:38
In the book that Gary refered to, the Super M had a test of 12.01 fuel economy at 33.33 HP, the AC45 had a fuel economy of 12.34 at 40.47 HP, the 60 JD had a fuel economy of 10.22 at 28.04 HP, the 70 JD had a fuel economy of 10.33 at 33.11 HP, and the Super 77 had a fuel economy of 11.67 at 41.48 HP. Jim
IaGary
12-31-2006 05:40:10
The book Nebraska Tractor Tests Since 1920 by CH Wendal has all these tests and figures that you want.
Also The Agricultural Tractor 1855-1950 has all that were tested before 1950.
I can get these numbers if you desire but it would take awhile.
Gary
Thanks
12-31-2006 05:43:11
 Re: IH,JD,AC,etc in reply to IaGary, 12-31-2006 05:40:10
Do you know of an easy data sheet showing like tractors? Jack
Jeff Oliver
12-31-2006 08:23:53
 Re: IH,JD,AC,etc in reply to Thanks, 12-31-2006 05:43:11
try www.tractorinfo.com. They have alot of the nebraska test results there and should have those.
IaGary
12-31-2006 05:55:44
 Maybe Nebraska Cowman can help out. in reply to Thanks, 12-31-2006 05:43:11
Cowman did they get this infro on that web site yet?
Gary
