Tractor Talk Discussion Forum
O ring groove
37 chief
12-29-2006 16:58:48
I am in the process of cleaning the O rings grooves for my JD 4-219 engine block. I am finding the water side first O ring shelf pitted a lot. The bottom two are in good shape no pits. Since there are two good O rings grooves, is it necessary to have a perfect surface for the first O ring (which is actually square) I will need to sand thec crap out of the block to get the pits out for the first water side ring. Is it really necesary, or will the rubber squeeze into the pits. thanks for any info. Stan
Tom in Central Pa
12-30-2006 06:11:41
 Re: O ring groove in reply to 37 chief, 12-29-2006 16:58:48
When I assemble those, I use a small amount of silicone sealer on those parts, figuring that the silicone will ease the assembly, and then fill up the pitted places. Just my $.02 worth.
msb
12-29-2006 20:40:51
Clean it as good as you can and then touch the pits up with JB Weld and sand the goves smooth with no high spots in them.
No tools
12-29-2006 18:37:57
37chief
Say is the oring groove on that engine in the bottom of the sleeves or in the block.
if they are on the sleeve just clean the block for rust an put it together.
If it's like most engines that upper most oring does not go very deep in that bore.some engines not at all it's allmost like a safty.I use silicone lubicant to put them in have'nt had any trouble?
Bill
37 chief
12-29-2006 23:31:30
 Re: O ring groove in reply to No tools, 12-29-2006 18:37:57
The grooves are in the block. The surface in question is not actually a groove, but what I would call a 1/2 groove. the liner has a step and pushes the ring into the block step. Stan
No tools
12-30-2006 03:23:06
 Re: O ring groove in reply to 37 chief, 12-29-2006 23:31:30
37 cheif
if the groove is in the block then shoot just clean rr good and put rr together. heck i've seen some pretty bad ones on the farmall a-b c etc with just one oring in the block.
Bill
