Tractor Talk Discussion Forum
PLEASE HELP ANYONE
TOM ADAMS
12-28-2006 20:13:49
PLEASE HELP I GET MY NEW FARMALL WD-9 TOMORROW AND I DON,T KNOW HOW TO START IT. PLEASE ANY ONE WITH INFO ON HOW TO GO FROM GAS TO DIESEL ON THESE THINGS PLEASE HELP ME OUT. THANKS. TOM ADAMS,
John S-B
12-29-2006 07:00:42
 Re: PLEASE HELP ANYONE in reply to TOM ADAMS, 12-28-2006 20:13:49
Do you have a dealer near you? See if they have the operators manual for it or it they can order it for you, you'll need it eventually.
hawken79
12-28-2006 23:05:26
Dont forget to shut it off on gas. Then after you shut it off put the lever back into diesel, this is to prevent the head from cracking. Closing the starting valves helps it to cool evenly. Have fun
Jim Johnson
12-29-2006 04:01:34
 Re: PLEASE HELP ANYONE in reply to hawken79, 12-28-2006 23:05:26
When you pull the lever down to put it on diesel it shuts off the gas. No need to confuse the issue I told him right.
Bill(Wis)
12-29-2006 04:11:02
 Re: PLEASE HELP ANYONE in reply to Jim Johnson, 12-29-2006 04:01:34
Again, I don't know about the 9 but Hawken 79 told him to shut the engine down at the end of the run on gas. Not to shut off the gas.
Bill(Wis)
12-28-2006 21:10:41
The IH Diesel Engine Page is a new website that has a chatpage on Thursday evenings (tonight). Good Luck. All I know is about the IH crawler model the Army used in the 30's to move coast artillery guns in and out of their caves. They had a big handle under the seat that was moved sidewards after starting on gas. Moving the handle accomplished all that was necessary to switch over.
Jim Johnson
12-28-2006 21:07:50
Well Tom first you have a short lever on the left of the steering column pull it up and pull your thottle (long lever on right) up. Make sure you have gas in little tank and on. Then turn your key on, pull the choke out and hit the starter it should start, then push your choke in, let it run and warm up for 30 seconds to a minute, then pull the little lever down and the throttle lever down a little at the same time and your on diesel. Simple as that. Have fun and I'm sure you will because they are a blast. Jim
TOM ADAMS
12-29-2006 10:10:12
 Re: PLEASE HELP ANYONE in reply to Jim Johnson, 12-28-2006 21:07:50
HEY THANKS ALOT FOR THE DIRECTIONS. I GO TO GET IN ABOUT AN HOUR AND ITS A BIG HELP. THANKS. SEND YOUR E-MAIL AND I'LL SEND PICS IF YOU WANT. THANKS AGAIN, TOM ADAMS
