Tractor Talk Discussion Forum
farmall h grille screen
JFAVOR
12-23-2006 10:47:00
I have a 51 farmall H. Trying to change the grille screen. Thought it would be easy but looks like the clips that hold it are spot welded. How do I remove them without causing more damage? Where can I get new clips to hold the new screen in place? Any suggestions? Thanks.
genos
12-23-2006 13:40:20
 Re: farmall h grille screen in reply to JFAVOR, 12-23-2006 10:47:00
I Have Changed A Couple Of Them, Try To Break The Spot Weld Loose, If You Can't And It Breaks Clip Off, I Just Put Some Weight On It From Behind And Put A Gob Of J B Weld On It. Gene
dfre
12-23-2006 18:11:07
 Re: farmall h grille screen in reply to genos, 12-23-2006 13:40:20
the clips are meant to bend over and crimp the wire mesh. I brazed some new ones on that i broke off. easy.
JFAVOR
12-24-2006 06:14:34
 Re: farmall h grille screen in reply to dfre, 12-23-2006 18:11:07
Thanks for the info. I think my clips are welded on both sides. Maybe I can grind one end loose. Now I know where to get new clips and screen but I think removing the old screen is going to be the big problem.
