Tractor Talk Discussion Forum
G John Deere
DALE Spackman
12-22-2006 08:12:34
Restoring a G John deere. The head is broken and the block has had water in the cylinders. To remove the block I had to disconnect the rods and remove the block as an assembley. The rods didn't have any bearings in them just alot of shims to adjust the clearance. This is a 1947 according to the serial No. This is the first time I've worked on an engine without rod bearings. Can any share some history on this engine and what is the best way to go with these rods.
430WLPG
12-22-2006 14:30:36
 Re: G John Deere in reply to DALE Spackman, 12-22-2006 08:12:34
The rod bearing your talking about was poured into the rod,look at the inside where the bearing would be, is there a lead looking material stuck to the rod and cap? If so that is the bearing surface and if it is undamaged it is reuseable(and is renewable by a some old engine shops)and is adjusted with those shimms in your case you will need to probably remove one or two from the upper and lower just be sure to keep them even.
Bob
12-22-2006 08:28:09
Unless the crank is rusted or worn excessively out-of-round, or the babbit is broken up, there's no problem at all with putting the babbited rods back in, and correctly shimming them.
