Tractor Talk Discussion Forum
tread
24d
12-21-2006 17:17:57
Want to put rubber tread on steel wheels (cut tires) whats the best way?
Leroy
12-22-2006 06:20:32
 Re: tread in reply to 24d, 12-21-2006 17:17:57
Am planing to do the same on manure spreader that belongs to Amish friend, Now they are allowed to do that for road travel. I plan to use the sazall and bolt the tread to rim with bolts with a large flat washer under the head with the nuts on inside of rim. But first I have to replace all the rotted away wood and some rusted out steel from the frame, also have to replace the rear axle that is wore out. Just need the time to get it done.
Jim Elder
12-21-2006 20:19:20
M.E.Miller Tire of Wauseon, Ohio has rubber lugs for steel wheels www.millertire.com 800-621-1955,ext.4
DLM
12-21-2006 19:47:04
Use a sawzall with a knife blade and a helper
with a spray bottel of lub works good.
Don
dsfsda
12-21-2006 19:08:30
Get some old tires and a sawzall and work at it...there's really no other way
