Tractor Talk Discussion Forum
What size gravity wagon should I find???????????
mnjoe
12-20-2006 19:16:36
What size wagon should I look for to pull behind my New Idea picker? Thanks mnjoe
mnjoe
12-21-2006 16:07:12
 Re: What size gravity wagon should I find????????? in reply to mnjoe, 12-20-2006 19:16:36
I will be using a 325 2 row pull picker with either 326 or 327 husking unit. Thanks mnjoe
JMS/MN
12-21-2006 09:18:32
The older (orange) Minnesota 250 boxes should have the removable front piece. Used to be made by Prison Industries, when they used to work for R&B.
Leroy
12-21-2006 05:42:07
You did not say what model or size picker but the older pickers will not work with those big wagons, new ones may but be carful that with the large wagons that if you get in soft groung therte is a possibility if you have a bigger tractor on the picker that you could litterly pull the frame of the picker apart, and when the pickers were made the boxes were 125 bu and 165 bu sizes, you may be able to get the larger ones under the wagon elevator but remember that you are pulling a lot more weight through the picker than it was designed for.
paul
12-20-2006 20:44:19
Here in MN, there are many 220bu Parker gravity boxes that have the removable front extension.
I have 4 now, work well with the picker, and paired they haul grain away from the elevator real well too.
--->Paul
IaGary
12-20-2006 20:23:44
third party image
Heres what I use.
Its a 225 bushel Kilbros wagon Model 350.
Its a close fit on the elevator to the wagon with that foot board on there.
Gary
John (C-IL)
12-20-2006 19:33:27
You are probably looking for a Ficklin 185, I have a couple of 231's, but the front extention has to be removed and you have to be careful when you turn or the elevator hits the side extentions.
