Tractor Talk Discussion Forum
Milage rates for dump truck
JHesler
12-20-2006 15:14:13
This is off topic but I posted in Classic Trucks and didn't get much of a reponse. A guy wants me to haul trash to the dump. I'm trying to find out what the going rate to charge per mile is. Driver time and dump charges will be billed seperately. I'm just trying to find out how much to charge per mile for my truck. The truck is an IH Loadstar 1800 dump. Load capacity 5 tons. Thanks, John
RodInNS
12-21-2006 12:19:45
 Re: Milage rates for dump truck in reply to JHesler, 12-20-2006 15:14:13
I charge by the hour. It's about the only real fair way to go. With a tandem, I won't work for less than 60 (Cad) an hour, which would be about 15 % exchange. With my truck, hauling heavy, fully half that goes into the tank... but that's with an N14-435. If you've got an old DT466 or something that's good on fuel, you might take longer, but you'll burn quite a bit less fuel. The N14 gets there fast, but it costs... There's no need to work too cheap, because it'll only cost you in the end.
Rod
Leland
12-20-2006 16:28:39
Find out what the local garbage haulers would charge them charge him the same
old
12-20-2006 15:36:22
When I retired from dump trucking I was getting $55 per hour and that was back in 2000 so I would think with fuel prices that the going rate would be more like $60-75 and hour.
pafreehling
12-20-2006 15:24:41
50 to 60 per hour is fair. Also if the area you are hauling to could be bad for puntured tires take it into account. 1 tire can cost you your profits!
jhill52
12-20-2006 15:20:59
Most dump truck time is charged by the hour. A single axle in my area of MI is about $50.00 per hr.
