Tractor Talk Discussion Forum
530 or 580 case?
Mike Veen
12-17-2006 17:47:36
I have a 1965 530d case ck backhoe .I'm looking at getting a 1968 580 backhoe.What are the differences between the two if any.I know the 580 has two less control levers for the hoe( more what I'm used to).
Mike Veen
12-19-2006 15:09:46
 Re: 530 or 580 case? in reply to Mike Veen, 12-17-2006 17:47:36
Easy to work on is good .I've had the engine out three times,torque tube,hi lo trans, 4 spd trans,and now the rear end out.Not much left.
farmboy steve
12-18-2006 05:12:30
I have had both. and if you can afford it, trade up to a 580C or later. they are much easier to work on and have more power both in the hoe and loader. the C model is componets put together. you can have the transaxel and transmissiom out on the ground to work on in 2hrs. the 580 takes 2 days. all of the hoses are much easier to get to on the C. if you get an extenda hoe, it had more power than the B. each series newer get better boyh to work on and in power.
