Tractor Talk Discussion Forum
Axle housing sizes of a 1066
IaGary
12-17-2006 04:50:23
Does anyone know if the axle size is the same on a 1066 as a 1086?
I might get started on that ROPS if I can start measuring here at home.
Gary
Erik in WI
12-17-2006 09:34:27
 Re: Axle housing sizes of a 1066 in reply to IaGary, 12-17-2006 04:50:23
Gary,
The '76 1066's axle housings have the '86 series cab mounts already cast into them. However, my 1086 has 3 1/2" axles, while my 1066 has 3 1/4" axles. The 1466 and the 1486 both have 3 1/2" axles. The 1066 is the same as my 966 and 826 at 3 1/4".
On an unrelated note, is that a gas 560 you are grinding with? I hated having to use the 560, as soon as that engine lost any rpm, it fell on its face. I went back to my M on the Gehl 65. It takes a little longer, but, I don't have to clean the hammermill out after the tractor dies!
Erik in WI
IaGary
12-17-2006 11:13:12
 Re: Axle housing sizes of a 1066 in reply to Erik in WI, 12-17-2006 09:34:27
Thanks Eric.
I knew the axle itself is larger on the 1086Than the 1066.
The housing is what I wondered about and you answered that also.
Yes its a gas 560.
It holds in there fairly well on the rpms after a little adjusting on the fuel screw.
But it runs a little rich at an idle.
Gary
no tools
12-17-2006 09:24:51
third party image
As far as i can tell the axle housings are the same size, width, thickness and length. here are some pics of a 1066 and a 1086. Have Allan double check the width of the floorboard. as far as i can tell the only difference is were the 1086 cab mounts on.
no tools
12-17-2006 09:25:24
 Re: Axle housing sizes of a 1066 in reply to no tools, 12-17-2006 09:24:51
third party image
another
no tools
12-17-2006 09:26:37
 Re: Axle housing sizes of a 1066 in reply to no tools, 12-17-2006 09:25:24
third party image
and another
no tools
12-17-2006 09:27:14
 Re: Axle housing sizes of a 1066 in reply to no tools, 12-17-2006 09:26:37
third party image
again
no tools
12-17-2006 09:28:16
 Re: Axle housing sizes of a 1066 in reply to no tools, 12-17-2006 09:27:14
third party image
and again
no tools
12-17-2006 09:29:13
 Re: Axle housing sizes of a 1066 in reply to no tools, 12-17-2006 09:28:16
third party image
almost done
no tools
12-17-2006 09:29:45
 Re: Axle housing sizes of a 1066 in reply to no tools, 12-17-2006 09:29:13
third party image
last one
