Tractor Talk Discussion Forum
PHOTO - old fashioned mowing machine
David in Wales
12-15-2006 09:45:32
third party image
Hi Gang;
Nicely restored Ferguson TE-20 (Tractor England)
with mid mounted finger-bar mower. Not many of these mid mounted type of mowers survived into preservation.
Tractor was made with gasoline, gasoline & vapourising oil, or diesel engines.
The "Fergi" was the biggest selling tractor in England in the late 1940's & early 1950's. Your equivalent in popularity would have been the Ford 8N I guess.
Cheers David
MJ in the UK
12-16-2006 05:03:29
 Re: PHOTO - old fashioned mowing machine in reply to David in Wales, 12-15-2006 09:45:32
Hi Dave, were do you keep finding all these tractors from. I have a 1951 Ferguson TED20 tractor with a Ferguson mid-mounted mower. Took it to the tractor show at Newark last month with a lot more TE20s to celebrate 60 years since the first UK built Fergie. ASa matter of intrest the 2007 national road run is setting of from the Lincolnshire showground so we may be going through Ingham as you can get out of the bottom end of the village down a green lane. They want me to help them with the route so i will keep you informed. Regards Michael.
BrianRM
12-15-2006 17:39:18
Hi David..... excellent pictures as usual from you. What kind of weather have you been getting in your part of the U.K. this December? Its been unseasonably mild the last few weeks in the southern Ontario where I live.
Dennis in NC
12-15-2006 15:40:24
WE GOT A DIFFERENT KIND ROUND HERE . I THINK THEY CALL THEM SHEEP.
Tom R Ne
12-15-2006 14:08:31
Nice pictures David keep them coming.
Years ago in our area this type of mower was used as a highway right-of-way mowers, as they had a short connecting rod rather that a long pitman and would mow along a bank with the bar in almost a vertical position.
I had a Dearborn (very similar to this picture) on an 8N, that mower was often referred to as a Detroit Shaker as it would sometime give that little old tractor a good shaking. It was a 6� and a great fence line & bank mower. I also mowed some hay with it.
Larry McCreery
12-15-2006 10:48:12
I just happen to have a mower like that out in back off of a 8n ford.it is complete except the pully that goes on the pto.
JOHN HARMON
12-15-2006 10:41:45
Before Mower/Conditioners my Dad had a Ford 8n with a side mount Sickle Bar Mower much like the one pictured and he pulled a 4-bar JD Rake for Green Chop for our Dairy Herd.He could have had a Cutter Bar attachment for the Chopper but that would have cost more money than he wanted to spend.
Aaron Ford
12-15-2006 10:31:11
Hello, nice tractor. I would likely be the one skewering myself on the sickle bar from trying to mount it from the wrong side. I do stuff like that...
I was curious if the coil on this tractor was mounted vertically beside the distributor or horizontally above the starter. Just Curious,
Let's go Mountaineers,
Aaron
R. John Johnson
12-15-2006 09:58:08
David
What actually does the cutting? looks like a sickle bar mower other than the box around the cutter bar.
John
in-too-deep
12-15-2006 10:05:38
 Re: PHOTO - old fashioned mowing machine in reply to R. John Johnson, 12-15-2006 09:58:08
Kinda looks like they put that box on there for safety. Looks like plastic zip-ties holding it on. I see that type of thing at shows sometimes so folks don't get hurt.
