Tractor Talk Discussion Forum
4020 drawbar support
nickg
12-10-2006 16:48:07
I have a 67 4020. My drawbar support seals are leaking and decided to replace them. I am having trouble trying to get the retainers outso I can get to the pin that goes threw the tractor.
Mike M
12-11-2006 08:14:35
 Re: 4020 drawbar support in reply to nickg, 12-10-2006 16:48:07
Before you go any farther get yourself some of those aftermarket bushings ( maybe you have them now ) with the o-ring built in them and may as well figure on a new shaft too and get a shim kit to get rid of all the side play. This way you shouldn't have to redo it.
msb
12-10-2006 19:08:18
If you have removed the two small bolts that hold the plugs in then you should be able to pop them out with a couple of large screwdrivers.You have drained the transmission, haven't you?
nickg
12-11-2006 17:19:45
 Re: 4020 drawbar support in reply to msb, 12-10-2006 19:08:18
drained the fluid 1st thing. It was time to change it and the filter as well. Thats what fueled this maddness. I tried 2 of my flat punches may be I am just not holding my tongue wright.
