Tractor Talk Discussion Forum
how to check antifreeze levels
David McDan
12-10-2006 09:03:05
Hi,
I've got a JD 730 D that has sat for 1 month without running....can I check the antifreeze concentration without stirring up the antifreeze by haveing to start the tractor.
In other words, does the antifreeze and water separate over time? Really dont want to have to start the tractor again.
hay
12-10-2006 09:13:53
 Re: how to check antifreeze levels in reply to David McDan, 12-10-2006 09:03:05
if the antifreze/water mix seperates then something is wrong with the antifreeze. they should NOT seperate at all under any conditions according to the mix. i have an old tractor that sits for several months without running it and the coolant mix is the same as when it was put in. i check mine with a antifreeze tester when the engine is cold, although it can be done when it is warmed up also.
Don L C
12-10-2006 09:10:39
The antifreeze and the water stays mixed as one .....you can check it any time.....
RustyFarmall
12-10-2006 09:10:37
Anti-freeze will not seperate from water. There is no need to start and run the engine.
Willy P
12-10-2006 09:08:11
 Here's what I do in reply to David McDan, 12-10-2006 09:03:05
I don't worry about the antifreeze separating from the water. I drain some into a coke can and put it in my freezer with a thermometer and give it 24 hours and if it does not freeze then it is good if it does freeze then I check the thermometer and check temp amd go from there. HTH
Bill(Wis)
12-10-2006 14:58:59
 Re: Here's what I do in reply to Willy P, 12-10-2006 09:08:11
Most freezers bottom out at around 0 F. I trust it doesn't go below zero where you're at?
Jon Hagen
12-10-2006 10:07:41
Check your antifreeze tester. Most are accurate within a certain temp range. If the coolant is too cold ,you may need to let the sample warm to get an accurate reading.
