Tractor Talk Discussion Forum
PHOTO - unusual M-M tractor
David in Wales
12-06-2006 14:27:00
third party image
Hi Gang;
This small M-M is part of Henry's collection. Not a model ever imported into UK, so cant tell you anything about it.
Can anyone identify it and tell us what it is.
Cheers David
JOHN HARMON
12-06-2006 20:44:51
 Re: PHOTO - unusual M-M tractor in reply to David in Wales, 12-06-2006 14:27:00
A U.S. Military Contract version of a MM Jetstar.Nice little Two Bottom Plow Tractor for the size.I wonder if it was issued to the Military wearing it's present Color?John
rpllr
12-06-2006 18:43:11
looks to me like a jetstar or a bigmo 400. the grill emblem is the same as a jetstar not a 445. the front axle is turned around from its normal position. MM sold these tractors to military specs and they probably specified a gas tank capacity that was greater than the stock. They also wanted to keep it cheap so it had a barrel tank and no torque or extras. probably has an external side oil filter and a tall distributor base. I can also see it has the large hubs on the rear like a jetstar 3 industrial or a bigmo.
Gary from Muleshoe
12-06-2006 17:42:47
I was in the Air Force for twenty years it was very common for US tractors to be shipped overseas. This was most likely propane originally but when shipped to the UK gasoline was probably the wiswer choice. USAF did concern themselves with original looks when they converted things. Looks to be a 445 to me, serial tag should say the model number.
jwal10
12-06-2006 17:20:17
Hi, was this a propane tractor changed over to gas.Gas tank put in place of propane tank. Just a thought.
sfdasd
12-06-2006 17:13:36
how and why is a us air force tractor in the U.K.?
sammy the RED
12-06-2006 20:10:52
 Re: PHOTO - unusual M-M tractor in reply to sfdasd, 12-06-2006 17:13:36
Because we have had a base there since WWll.
Bob Da. (La)
12-06-2006 14:44:44
My guess is a 335 or 445 utility. Not enough of a Moline expert to know for sure. The fuel tank is definitely unusual though. I believe there are some numbers on the torque tube,lower right side that if you had them you could probably trace it out though. Thanks for sharing and God Bless.PS:Still praying for both you and your wife.
MJ in the UK
12-07-2006 02:24:35
 Re: PHOTO - unusual M-M tractor in reply to Bob Da. (La), 12-06-2006 14:44:44
Nice picture Dave, Several ex USAF Oliver 88s are in preservation here in the UK. They were fitted with large magnets underneath them for picking up nails etc from the runways. As you maybee know Dave that Sonny Smith from Shrewsbury has one. MJ
