Tractor Talk Discussion Forum
rear differential axle cover plate ford F600 1968
bill huddleston
12-06-2006 10:38:20
this in not exactly a "tractor" but it is old. got this dump truck recently and someone had removed the cover "plate" off the rear end. I imagine it has a bad bearing somewhere in the rearend cause no idiot would remove that cover for the fun of it. I would like to get the bolts too if possible.
Rear axle is F3K cover plate has 12 holes and would measure 15 1/4 inchs across centerline of 6 holes. this part was problaby used on other year fords and maybe other make rearend of that time.
help. anybody got one or know a source???? cant tell manufacturer of rearend yet.
KEH
12-06-2006 14:45:06
 Re: rear differential axle cover plate ford F600 1 in reply to bill huddleston, 12-06-2006 10:38:20
Have an old 2 speed rear end from a 1955, I think. I will take measurements tomorrow if one does not turn up for you overnight. Am in SC.
KEH
bill huddleston
12-06-2006 20:18:52
 Re: rear differential axle cover plate ford F600 1 in reply to KEH, 12-06-2006 14:45:06
will check your reply on Friday. thanks bh
KEH
12-07-2006 14:05:15
 Re: rear differential axle cover plate ford F600 1 in reply to bill huddleston, 12-06-2006 20:18:52
Bill, Appears to be samee measurements, also bolts are 3 3/4 inches apart, center to center. I am going out now(about 5pm EST) for a visitation. Will check back later or you can email me.
KEH
kouvakis
12-17-2006 20:09:39
 Re: rear differential axle cover plate ford F600 1 in reply to KEH, 12-07-2006 14:05:15
I have been in several sites including Ford enthusiasts site with no luck. I am down to welding up one from light steel. Maybe i could alter yours what is diameter of the cover without the flange? mine would be 14 1/2 or atleast 14 inches what is depth? sorry to be a bother. how much do you want for it? will pay shipping and packing.
bh
bill huddleston
12-10-2006 21:02:59
From centerline to centerline of each of 12 bolt holes on mine is 4 1/8-3/16 inches.
The depth of the bell must be at least 4 1/2 inches.
It does not sound like a fit.
bh
