Tractor Talk Discussion Forum
NEED HELP
Dennis in Wisco
12-02-2006 07:17:55
Just got a case uni loader 1737 (very old an wore out) and can*t tell for sure where to add hydraulic fluid ---- called case and they said outside left panel two square plugs in front of the rear tire and fill top plug till full --- this unit has one plug in middle of tire --- poked a wire down the hole to try an get fluid on it but got nothing --- can anyone tell me if this is the correct check point thanks so much Dennis
JD9295
12-02-2006 15:52:24
 Re: NEED HELP in reply to Dennis in Wisconsin, 12-02-2006 07:17:55
we had the same unit. The hole should be a 3/4 pipe thread for the filler. I put a 45 on it and left it in.
the hydraulic oil runs in both sides to oil the chains and clutches also, there should be a 1 inch hose under the seat down low that hooks both sides together and feeds the pump.
