Tractor Talk Discussion Forum
Hey Allan I need help
todd in ne.
11-27-2006 16:45:15
Been fighting my 806. It won't start! I charged the battries up good and all I get is a faint click. Battry cables are all good and clean Tried a new key switch and a different push button for the starter and still just a click. Tried shorting the solinoid and it spins the starter a little bit then click. Do you think it is the starter or the solinoid? Almost forgot I put a jumper wire on the saftey switch on the cluch pedal too. What do you think? todd
ejr-IA.
11-27-2006 19:01:13
 Re: Hey Allan I need help in reply to todd in ne., 11-27-2006 16:45:15
Sounds like the contact in the solenoid is burnt.You can turn the copper contact a half turn and get a new area to make contact.
todd in ne.
11-27-2006 19:32:27
 Re: Hey Allan I need help in reply to ejr-IA., 11-27-2006 19:01:13
Thanks I will try that with the soliniod before I buy battries. Those things are not cheap. As far as the ground cable it is good and shiney.
IBorange in TX
11-27-2006 18:51:55
Sounds like a bad ground around the battery cables.
Good Luck..... .
Allan In NE
11-27-2006 16:58:47
Are you getting that ratchety clickity-click out of it?
Gut tells me it is still a battery deal. If it still has the 6 volt dudes in it, they are in series, they are like a chain with a weak link, so a bad dead one kills the other.
I'd really look at those batterys hard.
You need a tractor and a loader? I can haul ya one over there if you're in a bind and need to feed. You know it won't cost you a dime.
Allan
todd in ne.
11-27-2006 17:16:20
 Re: Hey Allan I need help in reply to Allan In NE, 11-27-2006 16:58:47
Allan I'm gettin just one faint click when I hit the button. I guess it could be the batterys. It has been starting fine but one could have went bad. I'll check them out good. I don't need a loader but thanks for the offer. How do you like that heated cab?
Allan In NE
11-27-2006 17:33:40
 Re: Hey Allan I need help in reply to todd in ne., 11-27-2006 17:16:20
It is the high light of my day this time of year. Just plain sweet. Now, I know how your dad felt as I watched him feed all those years ago going past our place. :>)
Hollar back if you need anything.
Allan
