Tractor Talk Discussion Forum
Another Ford 4610 4 CYL.
CurtisB
11-24-2006 06:04:12
There is a Ford 4610 4 cyl on ebay. Its not mind , just another one i found. Thanks, Curtis
RickB
11-24-2006 12:22:26
 Re: Another Ford 4610 4 CYL. in reply to CurtisB, 11-24-2006 06:04:12
I just searched ebay and found 2 F/NH 4610 3 cylinder tractors, how about you list an item number so i can take a look?
CurtisB
11-24-2006 12:47:35
 Re: Another Ford 4610 4 CYL. in reply to RickB, 11-24-2006 12:22:26
WWW.medinatractor.com 1-800-589-5995 Do a search on ebay for Ford 4610, its at the bottom , where it says Buy it Now
Curtis B
11-24-2006 15:10:09
 Re: Another Ford 4610 4 CYL. in reply to CurtisB, 11-24-2006 12:47:35
Rod, an Rick, i only posted what i found, i have know idea what it is. I don,t really know what i,ve got, except it has 4610 on it an it has a 4 cyl. engine. Thanks, Curtis
RickB
11-24-2006 15:30:04
 Re: Another Ford 4610 4 CYL. in reply to Curtis B, 11-24-2006 15:10:09
My comments are directed to the tractor on ebay, which to my mind is clearly a 3 cylinder tractor as pictured.
RickB
11-24-2006 13:55:03
 Do you believe all you read? in reply to CurtisB, 11-24-2006 12:47:35
OK. The ad says 4 cylinder, but the photo shows a hood only long enough to cover a 3 cylinder and the engine block isn't long enough for it to be a 4 banger. 4610's came with 3 cylinder engines only. Maybe Rod or Bern will come along and back me up here.
RodInNS
11-24-2006 14:31:18
 Re: Do you believe all you read? in reply to RickB, 11-24-2006 13:55:03
Will do. Far as I know the 4xxx post '65, only had the 3 banger 201. However, we've been chatting about this 4 cylinder 4610 that he's got, which seems to have all the correct date stamps between it's castings anf info tag. So, he's got me? I mean, I do know about the 4 cylinders that got stuck in the 3 cylinder chassis for the 4810 and the 4830/5030, but they've got some sort of id....
The only 4 cylinder variant on the 4610 that I'm aware of was shipped to South Africa. I'm not sure if final assembly was done there or at Basildon, but the tractor was fitted with a Perkins ADE236 which was made under licence, in South Africa. I think at the time there was a law there that stated that any tractors under 100 hp needed to have a locally sourced engine, and that outfit had the grip.....
Other that that, I can honestly say that I've never seen a Ford tractor, with a 4 cylinder engine, badged as a 4610.
Rod
