Tractor Talk Discussion Forum
What's a velum gasket?
Just Plain Joe
11-23-2006 11:55:42
In a parts manual list here I see what they call a "velum" gasket. The original one was destroyed somewhat but it appears to be a thin and brittle type of material. What exactly is velum?
KEB
11-23-2006 13:14:55
 Re: What's a velum gasket? in reply to Just Plain Joe, 11-23-2006 11:55:42
Vellum was also used for engineering drawings prior to the advent of computerized drawing tools. Because it's semi-transparent and tough, an original drawing done in black ink on vellum could be used to make many blueprints.
Any art supply store should have it.
Keith
rgvtx
11-23-2006 12:56:11
I always understood vellum (with two L's) was just a paper type gasket. After a quick internet search I found this, so I guess I was about right.
In the 1890's, a professor of chemistry at Amherst College discovered that certain paper, when impregnated with a solution of glue and glycerin, was transformed into a crackle parchment-like material that was waterproof, oilproof and greaseproof. Because of it's parchment-like quality, the material was called "Vellumoid" (meaning "like vellum or parchment"). Since our humble beginnings, Vellumoid Incorporated has become a major producer of gaskets for automobiles, trucks, and miscellaneous sealing applications.
Dale B
11-23-2006 12:53:07
I have some old rolls of Victor gasket paper mfd in the '40's and it has a sort of watermark overprint saying Vellumoid Paper all over it. Wikipedia says it is a name now used for pigskin , leatherette and other sturdy papers used in book covers. My paper is very stiff and when I use it , I wet it first to soften it some before cutting .
dr.sportster
11-23-2006 12:50:17
I think its[a least vellum with two Ls]is used like on a Sportster oil pump when they dont want you to pinch gears even though its still possible to overtorque and do this.It might be a plastic or hard paper Im not really sure.Its probably of a specific thickness whatever it is and using gasket paper to replace it would ruin some desired clearance.Maybe someone who knows for sure will respond but Im guessing if a manual is calling for it dont substitute a homemade gasket.Ill venture another guess its on your oil pump??
