Tractor Talk Discussion Forum
mf 65 smoking like a train
kyler2479
11-18-2006 15:59:37
i have a 64 model mf 65 wiht the direct inject perkins it smokes out the exhaust pretty bad combo of blue and white but normal black smoke when you bog it down or rev it up it burns some oil not real exsesive doesnt miss nock rattle or anything itll crank up hot it does need a snort whenits cold another note the stock oil pressure gauge stays pegged whenits runinng so i stuck an oil gauge i know is accurate on just to see and i makes 60 psi at idle and 75 wide open any help would be great
edwin
11-19-2006 08:05:32
 Re: mf 65 smoking like a train in reply to kyler2479, 11-18-2006 15:59:37
A friends mf65 was smoking like a train a few years ago ,I had to keep way back behind him on the road to avoid the smoke , I cleaned the air breather oil bath also under side of gause above oil bath that evening and it ran beautifully ,still going 10 years later . also check the air breather hose is not collapsing when the engine is reved up, those engines are almost indistructable
RAB
11-18-2006 23:23:03
Are you just telling us about your tractor or do you have a question? 40 years on, it has lasted well. It may deserve an overhaul. It may have had two or more previous overhauls, I don"t know.
Do a compression test or compressed air test on your engine. You may find out it is a bit low on compression. Your oil control rings may be at the end of their useful life. You may have oil leaking down the exhaust valve guides, although that is less likely on a diesel. You may have broken compression rings from using ether.
Does it lose compression into the water jacket?
I would suspect it may be needing a good overhaul.
Regards, RAB
kyler2479
11-19-2006 05:17:02
 Re: mf 65 smoking like a train in reply to RAB, 11-18-2006 23:23:03
yes it was a question thanks for the response it doesnt loose compression into the radiiator it doesnt have compression when it sittin you can turn it over by hand if ya crank it up then cut it off you cant hardly move the fan by hand then you can hear air hissing when it stopes you can turn it over easily by hand again
RAB
11-19-2006 12:47:38
 Re: mf 65 smoking like a train in reply to kyler2479, 11-19-2006 05:17:02
If you have no compression at cranking speeds, you definately have a problem. Are the valve settings correct? I had forgotten about the possibility of a blocked air cleaner as I would expect it to be checked regularly.
Sounds very much like valves or rings. A compressed air check would let you know where the air is leaking to.
kyler2479
11-19-2006 05:16:07
kyler2479
11-18-2006 16:19:50
the snort of either is only in cold wether not engine cold and oil pressure at operating temp
