Tractor Talk Discussion Forum
Odd Bolt
Pete7
11-16-2006 10:20:58
Was fixing a tool made in China yesterday and came across a crazy bolt. It had a metric head and standard American 1/4" threads. So it isn't metric nor American, a hybrid. It was threaded into a cast fitting, but if it wasn't, it would have been interesting to see what size nut they would have put on it! Anyone else see this kind of mixture...it's new to me and seems stupid. Pete
NC Wayne
11-16-2006 20:24:46
 Re: Odd Bolt in reply to Pete7, 11-16-2006 10:20:58
It's not that common but I've been seeing odd mixes of standard and metric in bolts for about 7 years now. The first encounter was a 5/8 course thread bolt with a metric stamped 10.9 head. Many of the head sizes are so close together between metric and standard that you can go either way when using a wrench or socket and not know any real difference, expecially if the head is worn a little bit. I routinely run into button head allen screws that take a 5mm allen to fit them but the thread is 1/4-20. I hate metric fasteners with a passion mainly because it requires me to keep two complete tool sets on my truck to be able to work on anything because of the inevitable mixing of standard and metric on machines. I just wish someone would make up their mind and make the ultimate decision and go either all metric or all standard and end all the mixed up crap. The bad thing about that is if they decided on all metric there are still alot of special tools that still aren't available in metric sizes...and that would just make my life that much harder and stretch my tool buying dollar that much more trying to get the ones that were available..... ...
Roy Suomi
11-16-2006 16:00:24
I've never seen 1/4 - 20 grease fittings...I've seen plenty of 1/4 - 28
Aaron Ford
11-16-2006 11:12:41
My "Made in China" Utility Trailer had 1/4-20 threads on the zerk fittings. Try finding that...
teej
11-16-2006 11:19:16
 Re: Odd Bolt in reply to Aaron Ford, 11-16-2006 11:12:41
I've never had trouble finding 1/4-20 threaded grease fittings.
I've seen them used on a lot of equipment. Local John Deere dealer stocks them, as does the Carquest down the street.
Gerald J.
11-16-2006 10:49:48
The drive shear bolt for a MF-12 baler has a metric shank and an odd fractional head. And uses a metric nut if I recall correctly.
Gerald J.
Don-Wi
11-16-2006 10:59:33
 Re: Odd Bolt in reply to Gerald J., 11-16-2006 10:49:48
I can't say what size the shank is on those bolts we buy for our 12(woulod guess 3/8 though...), but it's just a 1/2" wrench for the bolt and the nut. Pretty sure the threads are 5/16. Not al that odd ball to me, it just has a thicker shank that reduces down to smaller threads. Standard no, but each manufacturer had a different type of bolt. This way the farmer couldn't get lazy and go with a grade 8 instead of using the right bolts, and end up wrecking something else....
Donovan from Wisconsin
