Tractor Talk Discussion Forum
OT-ignition switch 1979 GMC
PJBROWN
11-15-2006 19:38:16
I have to change the ignition switch in a 1979 GMC 1 ton. Does any one know if I have to pull the steering wheel and go in from the top of the steering colum. Or is there a way to just pull it out the side? Any help would help seeing how I have never done one before.
Bob
11-15-2006 20:04:29
 Re: OT-ignition switch 1979 GMC in reply to PJBROWN, 11-15-2006 19:38:16
The ignition SWITCH sits on top of the steering cloumn, down about over your shins, when seated in the vehicle.
Access is by removing 2 nuts, and dropping the column down on the seat.
The LOCK CYLINDER is (obviously) located higher up.
Which do you actually need to replace?
If it is the LOCK CYLINDER, the steering wheel and anti-theft wheel lock plate will have to come off. The three screws have to be removed retaining the turn signal switch, and then the TS switch wires need to e freed up down below, allowing the TS switch to be pulled up, out of the way, and, then, at last, you will have access to the special screw that retains the lock cylinder into the column. (The older ones had a tab you had to depress, in about the same area the screw is located in the newr ones, and I think the change was made by 1979. Anyhow, you need to get doen into that area beneath the TS switch to remove the lock cylinder.)
BT,DT, a few times too often!
